thepremier
- Dec 31, 2005
I have been having problems with my car shifting into park for about the last month now... Everything else seemed to be perfectly fine with all of the other gears, but when I would go to park my car, I would have to repeatedly try to put the car in park as it would not always shift into park on the first try (while in park the car would start rolling backwards and making a clicking sound until I would stop the car, and take it out of park and then put it in park again).
Also the there were times when I couldn't get the ignition to lock even when the car indicates that it is in park. I would have to play with it just to try and get the ignition to lock and remove the key.
Yesterday I jacked up the car, and removed the shifter cable, and it appears to me that it is damaged as you can see in the picture. I'm not an expert on if this could be the cause of the problem, so I wanted to post here on the forum to get the feedback of you fellas who are more knowledgable of what the problem could be.
Than You
Than You
