Hi fam. On my dual intrepid fans,high speed not working, low speed does. I swapped the relays around and still didnt work so i went and ordered 2 new relays and same problem. I also have a brand new caspers dual fan harness. I looked at the trouble shooting guide. I unhooked the the highside harness on the back of the ac compressor. I grounded the dark green wire and the low speed fan came on. I grounded the green with yellow stripe and i can hear the relay clicking(same as before i changed out the relays).i also took the coolant plug out the intake and grounded it and still hear the clicking. I tested the fans before installing in the car and both speeds work. How do i get this thing working correctl?
