Pull the door panels. Inside the door you will find that there are many adjustments that you can make to the window assembly. I bought a window adjustment book from Kirban before I did mine and it was a lifesaver. That said, the adjustments will take time and patience but you can usually get a better fit once you move stuff around a bit.
Good Luck.
