forcefed86
- Jul 28, 2005
Just had the ECU checked by Bob a few months back. Car has been running fine since.
Last weekend it started running rough. After a little trouble shooting I found the #1 injector was not firing. I'm getting full voltage at the plug. Noid light flickers just fine on the no.1 inj. lead. So I figure its an injector issue.
I pulled all injectors and set them up on my test rig. Pumped inj cleaner through them all and cycled them with 2amp 12v. All seemed to work fine. I re-installed them all the the car ran great.
Today (week later) the car runs rough. I went right to the #1 inj again, but it worked perfectly. Now the number 6 injector is doing the exact same thing! So I Ieft the injectors installed this time and brought my inj pulse setup over to the car. With my 2amp 12v power supply The #6 injector worked perfectly. Plugged it back into the engine harness and everything is ok again. Car drives/idles great.
I've confirmed I get bat voltage at the inj. leads. Noid light confirms they all pulse as they should.
Anyone have any ideas? The only thing I could think of is I'm not getting enough voltage at the injectors? The grounds are all ECU controlled correct? Not much I can do to help that. Can I wire in an "IGN ON" power source that I know is good to the main power going to the harness? Is this common? I recently had a HG fail as well, I think this may have caused it.
thanks!
thanks!
