My check valve is installed on the HIGH side of the pump, between my pump and the nozzles..however, I am also using a solenoid valve in the line. So its like this: pump > check valve > solenoid valve > nozzles. The solenoid effectively eliminates any alcohol suction under vacuum conditions since it is triggered simultaneously with the pump. The reason for the check valve is because my pump and tank are in my trunk, it takes some time to build up pressure at the nozzles 18 feet away under the hood..so having the check valve ensures I always have 130+ psi of water/alky in the short length of line between the check and the solenoid (the solenoid is very close to the nozzles). That way I get instant response when I nail the throttle.
