So I bought Kirban's 6 piece lower body bushing set for 3, 4 and 7. First and foremost, the best $40 I have ever spent on my car. What a difference these 6 rubber bushings made. Gone are the squeaks and rattles. Very easy to install. 30 to 40 mins for me. However, when I removed the number 7 bolt on the driver's side, it required a little more effort than the others. This is one that is the most exposed to the elements. Anyway, I did get the bolt out and I installed the new one with the bushing and it appears that I might have stripped the threads on the mounting point. I was wondering, if I needed to could I put a thread insert in to fix this issue or is this just not feasible due to the composition of the mounting point. If not I was also thinking about trying a bolt with more threads or a slightly longer bolt. Because there doesn't appear to be a way to get to where the mount point is without cutting through some metal. Anyway, the good news is that I don't think the bolt is going to move as I had it tight at one point and I added a little more torque then the bolt started to spin, not tighten.
