When the number is high,it means that the throttle blade is fully closed or close to it. If you close the throttle blade all the way,the idle will be low. When this happens,the computer will attempt to raise the idle by letting more air into the motor. It does this by opening the Idle Air Control valve. When the valve opens,it allows air to bypass (go around) the throttle valve and enter the motor. A high IAC number means that the IAC valve is open a lot.
If you open the throttle valve,by turning the throttle valve stop screw clockwise,more air will enter the motor through the throttle blade. when this happens the idle rpm will rise. When the computer sees this rise it will close the IAC (lessening the amount of air allowed to bypass the throttle valve) valve as much as it takes to get the idle rpm back down to the programed idle speed. The IAC number will fall. This is what you need to do. Then re-set the TPS sensor.
If you had a vacuum leak,you would have extra air entering the motor. It would cause the idle rpm to rise. The computer would command the IAC valve to close as much as it takes to get the Idle rpm back to the target number. If the vacuum leak is big enough,the IAC will close completely. This is all the adjustment it has in that direction. This is why,when you see an IAC number of zero,you probably have a significant leak. If the number is high,you don't.
