M mystic664 New Member Joined Jul 14, 2008 Oct 18, 2008 #1 Where is this located on the engine? I think mine needs cleaned, it revs at about 2K only when you first start it after you turnit off and restart it idle fine. What do you guys think? Thanks, Eric
M mikestertwo Well-Known Member Joined Sep 13, 2006 Oct 18, 2008 #2 It's screwed into the throttle body just under the throttle plate. It has 4 wires going to it. Check for vacuum leaks.
M mystic664 New Member Joined Jul 14, 2008 Oct 18, 2008 #3 Wheres the most common place for a vacuum leak? Thanks, Eric
