OK after headgasket replacement the car has idled rough, and sometimes not at all. The IAC is really high reading in the 90-150 range, the TPS wanders around (.36, .44, .38, .42. etc) with just the key on, when I unplug the IAC this stops and it is steady at .38. I tried to get the IAC down but I now have the idle screw all the way out (not touching the linkage) and the car is idleing around 800 and still fairly rough IAC still low to mid 100's. Should I replace the IAC? Something else?
I have tried a new TPS and it did nothing.
