I've always had problems with this and would like to figure out what I'm doing once and for all. I don't know if it;s more of an issue of AE, 02 gain, or what. Maybe I should go ahead and choke down on the correction limits since the tune is getting close but scared to since it's adding fuel.
As the bubble transitions around I see alot of correction. Around and under 100 KPA it's an issue of me needing to play around with MAP vs AE and TPS vs AE I'm sure. I mess with it, and usually don't correct my problem but create new ones. It drives fine for now, but I'd like to get it nailed later.
But what I'm concerned about is when I'm building boost. I tuned the table pound for pound from about 6 psi up. But as it's going through those same cells it adds alot. This is not the way I wanted to do it but I jacked up the VE numbers in those cells the amount it was correction and about the same amount of correction.
How much does MAP vs AE affect this? Any? The rate of manifold pressure change is slow when boost is rising compared to the change going from closed to open or partially open and under vacuum to open and almost instantaneaously rasing manifold pressure.
I cannot seem to upload these attachments. It gives me invalid file errors. If you would like to offer your input I can email my GCT and log files to you. I would appreciate it.
