I have posted this before, I have searched the archives and I have tried everything that I can think of and I still cannot get my car to stabilize the boost. It will almost always give me a 3-4# swing on shifts, usually falling off at the top of gears.
ex: leave the line, up to 19 through first, falling to 15#, hit second back up to 19. Falls back down to 15 or so and then
shift into third and the same thing. The car runs rich through the traps, with the 02 somewhere around .820. (although running this rich and this little boost It still went an 11.55@118)
Combo overveiw:
Stock ecm, reds chips (currently 107)
pt 53
THDP, w/ H/D actuator
Precision F/M ic
50# inj
GN1 alum heads
70mm TB
Atr Headers
214/214 hyd roller
Yank 3400 convertor
Staged double pumper, #8 #6 lines
I have tried everything under the sun, tuner style, bleed of valve, swithing the wastegate hose around, Diffrent chips, diffrent converters, diffrent w/g actuators, Opening the hole in the turbo and pressurizing the motor from the intake side of the turbo to the valves (checking for leaks in the i/c, set the air regulator at 20# and will stay there until I take the air hose away) and still nothing.
I am ready to tear the car limb from limb.
Should I just cut to the chase and do an external gate/controller?
Would an out board controller help?
I am so frustrated with this little pesky problem.
Combo overveiw:
pt 53
Precision F/M ic
50# inj
GN1 alum heads
70mm TB
Atr Headers
214/214 hyd roller
Yank 3400 convertor
