i dropped my motor in 13 hours all done took it for a ride and al was good next day bumped up the boost 25 psi on alky and wow until BOOM
i blew off the top half of the intake manifold so i got new gaskets and longer bolts and what do you know the same ****en problem i cracked a ring or melted a piston again 5100 dollars later and back to the same ****en ****
how would that crack a ring or burn a piston if that popped off it even dented the underside of my hood
