Did the conversion today, ran into some snags with the install but worked through them and got everything hooked up. After bleeding the ps and brake systems, I have a huge problem.
The brake pedal does not come back up after applying the brakes and the brakes stay applied. If you lift up on the brake pedal the brakes release. Of course you can hear the pump load up when they are stuck on. I did have some issues with getting the air out of the ps system, the fluid, booster, lines got very hot. Not sure if the pedal was stuck on at the time, it may have been and that may have been the cause of them getting hot. The brakes do feel awsome during that first apply, gets about halfway down and wow you come to a hard stop!. Just the pedal does not come back up by itself unless you lift up on the pedal. Feels like maybe something is hung up. Bad booster?
Looking for advice and direction.
