Well, the above is only true if there is an adjustable wastegate already installed, they were not adjustable stock. Must first get an adjustable one or make one by cutting a section out of the rod and threading the ends and get a $3 bolt from Home Depot.
Now before you do any WOT blasts of any kind, you need to make sure the fuel system is up to par. If it has the original fuel pump, it ain't ready for any kind of boost. An 18 year old pump isn't going to keep up and the sock is probably clogged up. So first order of business is get a Walbro 340 and a hotwire kit and new filter...then as mentioned..a scan tool of some kind and minimally a manual boost guage cause the stocker is very inaccurrate. If no scan tool that you can watch the road at the same time, then get a knock gauge also...put the boost and knock gauge in an A-pillar mount.
Then you are ready to safely start the modding and upping the boost a little watching for any signs of knock.
You may think this is too much but if you do it yourself, and a fuel pump on these cars is easy...but fp, hw, guages will set you back about $350-$400.
And if you don't do this, be ready to replace a set of head gaskets minimally or at worst the entire motor.
Hey DarkBluT, where were you at last Saturday? We had about 14 Turbo Buicks at Redline! Last race of the year is Sat Oct 8th.
