A lot of us replace the ignition module at the same time, but to replace the coil pack give yourself about 1 hour of time or 2 depends how it goes for you.
Are you aware of the cylinder #'s and there order? Passenger side front of car is cylinder #2, cylinder #1 is front driver's side, #3 is behind #1 on the driver's side, etc. You will need to know this when doing the reassemble.
1) Pull all the plug wires.
2) I think it's a 8mm socket that fits the wire connector on the drivers side of the coil.
3) Take off the 3 bolts that hold the coil bracket on the car, the one that's toward the fire wall is a little tricky but doable.
4) Using a torx screw driver carefully disassemble the coil pack from the ignition module.
5) Unhook the wires between the two parts, note there locations.
6) Assemble the wires from the ignition module to the new coil pack after getting the gasket in the "loop" (once the wires are hooked up, it ain't gonna happen).
7) Reassemble in reverse order.
Chuck
