I know one of the things I am going to be told is to use the search function, but I did. I didn't see a write up where it explained how to replace both hinges, especially one that showed how to replace them without removing the door.
So, I have a new set of hinges that I got from a guy here on the boards a couple years ago, and have never installed. My door sags probably a half inch or so. I really want to get these put on soon so I dont have to keep slamming the door shut. I have seen for the upper hinge that you can loosen all bolts on the upper door, and loosen the bolts on the lower hinge that are hinge to door? and slip the top hinge out, and bolt the new one in. Is that correct?
So, say I do that, and I get the upper hinge in, everything tightened up and I still want to go ahead and replace the lower hinge. Can I do it almost the same way, just reversed? Loosen all bolts on the lower hinge, loosen bolts from hinge to door on upper, and remove lower hinge?
If doing it this way would work, would there be much adjustment necessary? I REALLY don't want to take the door off and cause myself a lot more headache with having to adjust the door to fit.
Thanks for any help guys!!!
