captndave737, I followed your instructions and everything was going as plan, up until I went to pull out the ac/heater unit and that's when I noticed that I somehow killed all of my interior lights? That being said, I was able to change out my stock bulb with my LED cool white to match the rest of my interoir lighting, but unfortunately they aren't working now. Is there a wire back there that runs all of the interior lights? I am going to look into this a little more when I get off of work tomorrow and I will also check my fuse box as well.Pull off the trim. Remove the four 7mm screws that hold the control head in place. pull the unit out a couple of inches. The peanut bulb socket is on the upper right of the unit.
That is possible. I will check it out tomorrow afternoon. ThanksOrange wires usually, check the 20A CIG/CLK fuse you probably pulled the wire off the cigar. lighter and it shorted out on some metal.
