Well if your only spraying one ounce at 24 PSI your going to knock with alky. If your running 28 degree's timing and spraying very little.. your gonna knock. If your fuel pressure/O2's are dropping hard.. your going to knock. But as my previous post stated... too many variables..not enough real info from you.
Yes 24 PSI shouldnt be a problem with an alky system "dialed" in.
But you dont give enough data for "real" help to be given.
Its not a Mconalds drive thru.. takes a little thought process to make things happen on limited octane.
Mike,
You said, "Not sure where 02's are, or what type of kit it is. I know I need to get a scan tool and check for actual knock and all that."
No scan tool...you'll never figure it out. End of story. Keep the boost under 14 PSI unless you want to do HG's again.
Dont mean to be harsh, it is what it is.
