I'm an ls1 guy, but I came here to learn more about alky/water injection because I know you guys have the most knowledge and experience around.
I'm trying to figure out what the ideal amount of water alky is. I've heard many different #s and mixes and I want to see what you guys have found to be optimal.
I'm currently running a 50/50 mix of water and denatured alky. I'm pushing in about 18% of my fuel volume at full boost/redline with a single m15 nozzle (I have the SMC kit). I've found this to be very helpful in fighting KR, but I still get a few blips of KR right about the time the alky/water % drops below 20% of my fuel volume. My timing is very conservative right now and I want to get a little more aggressive. I'm about to add in a second nozzle as an experiment, but I wanted to hear what % of fuel you guys are pushing in first.
I tired to follow the "turn it up until it falls on its face and then back a notch technique", but I can not get it to bog under boost with my current nozzle and pump. I also figured a more scientific approach would save me some trial and error.
I talked to one guy with a non intercooled ls1 that is pushing in 40% of his fuel volume and having great success (I have a pretty good intercooler and I’m not running as much boost as he is, so I don't think I need this much). A friend told me that 10% H2o is the ideal ratio. I found it interesting that I started to see knock just as my % of H20 to fuel dipped below 10%...based on 50% water 50% alky.
I did a test tonight and it looks like dual m15 nozzles will put me right around 25% of my fuel at redline (this does not include the impact of boost backpressure so it could be a bit lower).
I’m also interested to hear what you guys do when you put in race gas. Are you able to turn off the system completely? Do you keep it on and get more aggressive with the tune? Do you back down the pump speed? If so, how much?
Sorry if these questions are repeats. I tired search, but could not find the answers I was looking for.
Any advice or info would be greatly appreciated.
