G garrett Guest May 23, 2002 #1 How much torque for the nut on the turbine shaft after you rebuild a turbo? thanks, especially if you reply
I Intercooler New Member Joined May 24, 2001 May 23, 2002 #2 Call John Craig or PTE on that one. Something tells me 16 in.lbs. but I may be wrong
C Chris Taylor Guest May 23, 2002 #3 Limit Engineering, ask for John. (928) 453-7321 He is the Turbo Man!
John Larkin Sublime Master of Turbology Joined May 25, 2001 May 23, 2002 #4 I used 12 in/lbs and a drop of red loctite.
C Chris Taylor Guest May 23, 2002 #5 Hi John, I hope you had a good trip home from BG. It was nice to meet you and all of the TB.com people. Hope to see you at Bristol in Sept.
X XLR8N6 Guest May 23, 2002 #6 Originally posted by garrett How much torque for the nut on the turbine shaft after you rebuild a turbo? thanks, especially if you reply Click to expand... Just went through this. 18 in-lb. and then an additional 90 degrees. Got the info from John Craig.
