IC Mod
Fellas,
I have done this mod start to finish. I can help you with pics and any questions you might have regarding the install.
I used an 87 TB cause it came with the kit and bolted right up to the modded doghouse. The doghouse has to be modded by cutting the back half of it so that the roof of it is sloped downwards. Its reqd to make room for the turbo - otherwise your doghouse will not fit.
You can always buy an 87 doghouse yourself and see what has to be chopped then do it yourself or take it to a machine shop...no biggie.
I also bought a billet vac block for the top of the TB - and of course all new vac lines. You'll also need an 87 throttle cable.
Now as far as the IAC motor goes....the 84-85 coolant neck/housing is too tall and will interfere. Took mine off and chopped the roof off it then had a machine shop weld a top on it. Basically I made it slightly shorter.
Here's some pics....
