Gm
Gm has already come out with a V6 3.6L with DI this next year. It is a 304hp DOHC DI at 6200rpmthat is the top end motor for the Cadillac CTS. Mated to a 6 speed Auto in either AWD or RWD. Ought to be a peppy Caddy. Wonder how long it will be before they supecharge that DI V6. Was looking for specs on the bottom end of this new GM motor. You can also get the same DI engine in the STS. From what I researched the engine has almost 280lbs of torque at 5200 .
Found some cool stuff with DI V6 allows them to use higher CR 11:1, all aluminum block and heads, dual cam 4 valves per cylinder, forged crank,forged rods, high pressure fuel pump no return SS fuel system the max psi with DI is 1740psi. Injectors that vary flow pattern and resistant to heat ,injectors are under intake runners. No EGR the phasing cam can draw back exhaust to be burned by varying the overlap. pistons are coated and have aluminum pins and oil squitters, it's their highest output non turbo charged engine. The biggest thing is emmissions with the phasing and overlapping decreases NOX by 25% no EGR or AIR also decreses Hydrocarbons by 25% on cold start because fuel is directly put into combustion chamber, this is where the majority of hydrocarbons in the ozone come from Cold Starts. Makes you wanna hug a tree. Thought it was GM's 1st DI engine but I guess the had a couple 4 bangers come out this last year
They have a new ECM that controls the direct injection on this V6 which is their old VVTengine (variable Valve Timing) they gained over 15% INCREASE in hp. Would be interesting if one could try DI on a beefed up Stage engine, get the ECM, fuel pump, SS fuel rail and special injectors and intake, it it coil on plug design.
