Hey TurboDave,
I have the wastegate (stock adjustable actuator) puck set to just make contact with the turbo exhaust housing port. I have the bleeder valve mounted at the front of the car by the battery. The valve is slammed shut and I still cannot get a hold of the boost. It is over boosting all the time; I hate it and worry about damaging the engine. Some people think on a post about bleeder valves that smaller line to the valve, may be able to get the boost under control? I talked to Jack Cotton and he told me to port out the hole in the exhaust housing because he thinks that the exhaust can’t get out fast enough. Thus, the exhaust gas is still going through the turbine, driving it, making more boost. This makes sense to me, but it would be a pain in the a$$ to do. If the small tube will work, then great, if not any other ideas?
Here are some things that I've tried:
· Put on all new hoses
· Tested putting on a new "Y" that does not have the restrictor to see if that would drop the boost.
Thanks for any help,
Jason
