Well, just completed performing my first cylinder leakdown test. Approximately 2 months ago I did a compression test only and got satisfactory readings in the 150-155psi readings. Anyways these are the results using the dual gauge Proform leakdown tester:
Cylinder 1: 35%leakdown
Cylinder 3 30%
Cylinder 5 70%!!!!!!!!!!!!!!
Cylinder 2 40%
Cylinder 4 50%
Cylinder 6 25%
I turn the pulley to find TDC then install the gauge to get my readings. I also found out if I just inserted the gauge, the compressed air would force the cylinder to TDC and get the same readings as if I turn it into the compression stroke. To find TDC, I just listed to the compression out the spark plug hole or just a piece of straw inside to estimate the piston travel when at TDC. Either way these numbers are alarming and would be the answer to to why I have not been able to run any faster that 13.3 with the bolt on I have which should be good for low 12 or high 11's I would think.
I can not detect where the leakage is going to. I did not detect any coolant bubbles or air hissing by the intake or exhaust. No hissing or air hear escaping from the breather or dipstick. What should I do next to verify this test?
Cylinder 3 30%
Cylinder 2 40%
Cylinder 4 50%
Cylinder 6 25%
