69charger383
- Nov 14, 2005
Alright, its not a GN but this site has probably the best information on turbos and related parts cause thats all you guys deal with really. I have a 2005 Lincoln LS, its a 3.9L V8 DOHC with 10.75:1 compression, please dont say it cant be boosted cause others have already done it, one guy runs an Eaton M90 at 9psi with an air/air intercooler and theres 2 rear mount turbo guys running 5-7psi also with air/air setups. I want a traditional style setup tho not rear mounted. Car weighs roughly 3700lbs, has 3.58's and is getting a 3000rpm stall, max rpm is 6600 but under boost Ill probably only take it to 6-63 maybe. I was considering the gt6152 turbo or maybe even just a stock GN turbo for now. It WILL be intercooled, air/water and possibly have an alchy setup as well for safety purposes. Would like it to have a decent spool time and round off nicely up top, not looking for peak numbers or a hard "hit" if you will. I imagine with the compression ratio of the engine even a larger turbocharger will have a good spool time? Not sure tho. Any input is welcome and appreciated. Thanks guys.
