OK, I have the Low and High Bean ALRADCO HID light kit along with the 2 relays.
I have some simulated HIDS from years ago in there now and no longer have the factory harness so I need to figure out which wires to connect there also.
There seems to be some wires that have no place and quit frankly, don't see how they could be utilized with or without the relays.
Let's start with the LOW BEAMS, here is a pic with all of the questionable wires labeled, and the harness for the HID all plugged together the way they would appear to be installed, please check if I have them connected to the Ballasts correctly, doesn't seem to be another way.
From the pic:
'+' of the relay is going directly to the battery
'-' G 2 wires going to ground/chasis.
'1' is the 2 prong plug that I assume would go on the factory light plug. Looks like there should be 1-black wire, 1-green wire, and 2 tan wires would have been on that plug....which should go to the red and black wires on this plug labeled '1' in the pic above???
'2' - is a 2 wire weather pack connector and a red and black spade connector on the other end, these appear to have no use??? Maybe if I didn't have the relays they would plug into the weather pack from the Ballast, but the 2 spade connectors on the other end have no where to go and are on the wrong side of the bulb grommet to go into the factory harness.
'3' - same as '2' above on the other side, no where to be used???
HIGH BEAMS have a similar layout and same wires with no use as '2' and '3', just need to know what color wires, the factory green and black to which ones on the HID, red or black???
This kits looks like it will connect to the facotry wires on the driver side for both HIGH and LOW, does the passenger side factory wires just not get used and should be tucked away???
So, 5 questions above where I have '???' and please verify what I have connected together in the pic is correct.
Thanks in advance.
From the pic:
Thanks in advance.
