Last few months I have put Gessler ported heads, RJC head gaskets, ARP head bolts, Cottons downpipe and Razors Alky on my car. All these items were installed by well known and respected Buick technitions. Car has never run this good and I am very pleased with the results.
All of a sudden, a few weeks ago I get this noise that sounds like the down pipe could be hitting the passenger floorboard at full throttle only. Like a BAA-BAA-BAA-BAA at full boost. Half throttle...no sound...three quarters throttle...no sound. We had the car on the lift for hours and nothing is hitting anything. We even shoved rubber hose in between close suspect areas, did some runs, still get that sound.
20lbs of boost--alky set at #6....I use straight methanol.
as soon as boost comes up full throttle.....BAA-BAA-BAA-BAA
15lbs of boost--alky set on full....same thing
13lbs of boost--alky off.....no sound
Spoke to Jack and he said might be a head gasket. Back up on the lift, no signs of exhaust leak or gasket pushing out at head/block. No coolant leak, no funny oil.
The guy who installed and torqued the heads might have skipped the last torqing sequence. The car is going back to check compression etc, etc.
I really don't know at this point if it is a gasket or not,but can the RJCs be retorqed if there not blown out.
Has anyone ever had strange noises like this before......HELP !
