I have an LS1 MAF and 55/lbhr injectors and a walbro 340 FP.
The problem is that no matter what I do I run lean. BLM cell# 16 is at 100! but my O2s drop to the 690s before I have to let out of it.
I installed the 55s and the new walbro 340 in an attempt to help with the lean problem but it did not seem to help.
I only run 15 psi of boost and keep the fp around 40psi static.
The problem i am having is the exact same I had with the 009s and the ATR double pumper Fuel pump.....I have tried several chips and finally decided it was something wrong with the injectors or the FP sp I upgraded them both.
Fuel pressure rises as it should according to my FP gauge. (1psi of fuel fpr 1 psi of boost.)
I have GN1 heads and a comp 212/212 cam and PT54 turbo, but it even ran lean when I tried a TE44 still using the 55lb/hr injectors.
I am very very frustrated..... I am borrowing a good computer and hooking it up to my direct scan to see what it is doing this weekend.
Car is very lean...and VERY sluggish under boost.
I have already lost 3 headgaskets trying to chase down this problem and it is giving me a major headache.
max pulsewidth I see on DS is ~16ms
anyone had similar problems.
I will replace MAF and ECm and report back.....just looking for something obviouse I might have overlooked.
