Help me identify these injectors
GN18944
Long story short I just purchased a GN and the previous owner handed me a bag with the original injectors. However he was not sure what the ones were that he put in. Any help is appreciated.
What are the numbers on the injectors. No one can positively identify with that pic
Look at the chip, while you are trying to ID the injs.. If the PO doesn't know what he put in, he may not have the injs and chip matched..Along w/ other "stuff".
The chip may be tagged w/ the inj info, along w/ it's intended use.
Like mentioned the injectors should have part numbers on them. Once you get that number you can Google it to find out what info you need. It really is that easy.(y)
Thank you whitehot. I finally found a number on one I could see. Turns out they are bosch 45lb injectors. Thanks for your help!!
