My driver's side rear wheel wobbles when the tire is rotating (from positive to negative camber). Here is what I have done so far:
Properly torqued lug nuts, changed wheel for known good, changed out drum for known good. After this I put the car on jack stands, removed the wheels and drums, and watched the axle shafts with the car in drive. The driver's side axle shaft wobbled. I changed the outer axle bearings (old ones in good condition), and swaped axle shafts for new Moser's. Buttoned it all back up and the problem remains. Not sure where to go from here.
The car doesn't make any unusual noises or have any vibrations.
