josh watson
- Dec 1, 2006
L8......36-42
INT.....123
BL......128
CLT.....120
ATS........87
rpm.....850 ish
TPS.......42 (.42 rather)
IAC.....0
cc........ranging from 28-220
NAC?........0
o2 millivolts? Lowest 605 highest 710 (real readings....I now it fluctuates a bit at idle)
all numbers are at idle. My car is showing no codes and will not crank most of the time (I am going to look at the cam sensor). The problem is that when I can get it to crank it is running pig rich.
any input?
thanks. 87 t-type....new crank sensor, computer, ignition module...blah![Stick Out Tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
jw
INT.....123
BL......128
CLT.....120
ATS........87
rpm.....850 ish
IAC.....0
NAC?........0
any input?
jw
