M mcolor Member Joined Mar 26, 2013 May 7, 2013 #1 How hard is it to add a turbo to a carburetor 109 block
WarWagon Caustic Cacophony Joined Mar 10, 2007 May 7, 2013 #2 If your not afraid of work and fabricating you might try something like this: http://www.turbobuick.com/forums/threads/repeat-procedure.294806/ It's a blowthru carb turbo using as much oem and off the shelf parts as possible and making the rest, Having great results with a stock block.
