I gave it to some guy in a SL55 AMG at a light yesterday night, then at about the top of second gear, I heard what sounded like very loud and long whooooooosssshhhhhh, car nose dived and now I can't build any boost or hear the turbo spooling. Bear in mind I didn't embarrass the Turbo Buick community as the other guy let off when he quickly recognized defeat. (guy looked like the sheik from the Canon Ball run).
I then pulled over hoping to see the obvious inter-cooler hose that would have come off but it wasn't that obvious, it was dark and couldn't get a good look, actuator rod is still connected, so that didn't fall off , and I couldn't really get a good look at my cotton's front mount either to see if I split it.
What has me stumped is the car runs perfectly fine, idles fine, drove fine, BLM's INT all good. Boost was at 22psi at time. When I did try to give it a bit of gas, to see if turbo spools I can't hear it, but there is another sound that is hard to describe, best way to put it is a buzzing / fan sound if that makes sense.
Where do I look now. I'll start with the hoses, intercoller, I'll take the hose off of the cold inlet side of turbo see if it spins freely, check actuator rod.
Can anyone think of anything else, and would the car run as well as it still does if I have a major leak somewhere in all of the plumbing now . I'm hoping I just split a hose and that I couldn't see it last night but with my luck it's probably something bigger, I even fear that I might have split the inter-cooler open if that's possible. Hoping for some suggestions, I'm busy all day, I'll check here when I get back then dig into car and update what I find.
I have a trans brake and I was thinking of engaging it and working the throttle a bit by hand to see what's up but with my luck the rear view mirror will fall off, knock the shifter into second, propel the car though my back yard and into my neighbour's pool, it could happen because if it wasn't for bad luck I wouldn't have any luck at all.
Thanks guys.
Jim
Thanks guys.
Jim
