Headers
TTA1326
What's required to get the driver's side header off of this car? The passenger side looks to be a breeze, but the driver's side doesn't! Will it go out the bottom, the top with no extra work, or the top with extra things like the alternator removed?
There's the support bracket for the alternator (Y shaped) and also one for the ac compressor (L shaped) that need to be removed then you have the oil dipstick tube besides that and that you can get to all the bolts (studs) it should come straight up with some wiggling ...
Thanks Jan, I was hoping it wasn't as bad as it looks. I can get the bolts or studs with no problem, it just doesn't look like it will clear everything.
