Head gasket pics
Major Nutz
Got the heads off and found this. It's about to get fun! Is there anything I should do before I put it back together?
Yes...
Get new gaskets. :p
Seriously though, if you're still using stock head bolts, either get a new set from GM or buy an ARP set. Do not reuse the OEM TTY bolts.
Yes...
Get new gaskets. :p
ARP studs are on the list. ARP bolts were on it. I'm worried about the missing gasket material stopping up the pick up.
what's the number on those gaskets ? the fire ring looks very small/thin for a turbo head gasket ? maybe it's the pics .
I take it it blew to the valley?
Ditto on the oil pan check. You may want to also check the heads for flatness and clean the piston tops with a soft rotating wire brush.
If you wre runing AF and got it through, pull the motor.
You'll be glad you did.
blown gaskets
Here is a picture of mine.Make sure you put a new set of rod bearings or they will go bad due to detonation from blowing head gaskets...
drop pan!!!! what the hell happened? i see you have alky
Never,ever race when the gauge is on E. 25# of boost+no fuel=Costly mistake on my part, but I couldn't resist.:mad: Lesson learned.
Pan will be off in the morning. Heads will go to be magnafluxed for cracks.
Yours blew out all over the place! What gaskets did you go back with? I don't think I can use cometics because of the deck finish. Just curious.
Were you running water or anti-freeze? See some milkshake, and if there's coolant in that slush, bearings are bye bye....
For gaskets, I'd go with the 9441PT Felpros- no magic, they just work.
If you've already got ARP studs, no reason to change.
Yes, I was running anti-freeze. Guess I'll be replacing rod & main bearing.
Keep the tips comming. I don't want to miss anything.
Thanks,
Mike
Drop the pan and inspect before you jump to conclusions. If you shut it down right after it happened, you may not have damaged the bearings. If you drove it home............all bets are off!!
Dave
Dave
Will do. I drove it farther than I should have before deciding to call a tow truck:mad: probably a couple of miles trying to make it home.
