tim87tr
Obsession or Digression?
- Sep 19, 2001
I have a stock engine, Powerstroke IC, Razor alky car with a TA 49 and D5 and running 20 to 22 psi and might bump it a little when I get to the track. I have considering trying my spare trans and n/l 9" TC, stall should be around 3000-3200. Is this too much converter or possibly I should go with an .85 housing?
After having success with a couple other TRs, I don't feel my GN I've owned 8 years will get off the line as well with the current TA 49/D5. I did bump the timing up a couple degrees in first gear on the TT alky chip and am not sure that helped. I can always be patient and test out the current combo at the track before switching, but having the spare trans and 9" TC it is not costing me anything to swap them out. The car does run well as is with the exception of the initial launch. I also have an electronic boost controller that helps with spool. Opinions from any turbo gurus? (yes I searched )
