yes i have and it sucked for a street car... Its fine for a track car, but was horrible to drive around on the street with
The turning raduis is soo short you wont even be able to park in a parking slot with out having to back up etc..
suscribed... Illegal Regal, I would also like to see some cage pictures. Specifically, were you tied the nose bars to the dash bar. I like the smooth firewall.
thanks, I've still got more work to do to the firewall like extending the cowl all the way across and something different and cleaner with where the column pokes through. And add a couple more bars to the cage
Recurclating ball (original on the Regal) is superior by far to r&p. R&p is cheap & gets a wear pattern in time. Only reason Cadillac uses it, is due to space limitations with the Northstar - Cadillac owners can afford replacing it when needed.
The main reason that the car makers went to Rack & pinion is a little more coplicated than that. It's lighter, more compact, provides for a better road feel through the steering wheel, less moving parts, and more cost efficient for them to make. The drawback of putting it on a G body is since it wasn't designed for it it doesn't work as well for the application.
I wouldnt go so far as saying they dont work on a g-body. If you use a narrowed rack you wont get as much from lock/lock as stock but you dont have to use a narrowed rack either. You can use something wider and have the same exact steering movement.
The reason for the narrowed rack is to correct the bump steer these cars have.
