Cool.
One observation. The adapter will not be a straight fit due to the larger diameter of the compressor housing.
IOW, The connection needs to be angle cut to make it fit.
Personally, I would connect it with some silicone hose and t-bolt clamps which will allow you to use any other stock housing turbo.
Looks great.
That's pretty legit work man! I like it!
Very cool man. Too legit to quit.Yes the searches ive done in the past you did mention this info, but I dont think ill be using a hose. I would be to afraid of having it blow out.
I'll have to get it welded because from past posts theres been a few hoses pop out so to speak. Plus its a big turbo for another engine.
I have a bunch of the slip in type adapters if you dont want to weld to your housing.
Any time the compressor is exposed to vacuum you need a positive sealYou still need the turbo to have a carbon seal though?
Right, and an 86/87 turbo doesn't have this right? So since rude dog made this adapter to use the 86/87 turbo he still needs the turbos to have a carbon seal added?Any time the compressor is exposed to vacuum you need a positive seal
All garrett turbos used on buick engines from 78 to 89 were all carbon sealRight, and an 86/87 turbo doesn't have this right? So since rude dog made this adapter to use the 86/87 turbo he still needs the turbos to have a carbon seal added?
Oh I didn't know that, so you can use the newer turbos as long as you have the adapter!All garrett turbos used on buick engines from 78 to 89 were all carbon seal
You have to saw off part of the outlet and weld the new outlet on.Oh I didn't know that, so you can use the newer turbos as long as you have the adapter!
Cool
You got skills Rudy, nice work! You making extras?I was at work and fabbed up a turbo adaptor for installing an 86-87 turbo. It still needs to be cut to size once I measure the distance from turbo to intake and have the adaptor welded.
View attachment 227170 View attachment 227171 View attachment 227172
