Goal is 11s
maxcom
Except for the mods in my sig it's a 15k mile stock GN. The goal is a very streetable high 11s car with excellent throttle response. Assuming a proper tune will these mods do the trick?
Also considering the following;
TT chip and 60lb injectors
HR sway bar
Comp 980 springs
CK shift kit
Trans cooler
With a good tune, I don't see why it wouldn't. The H&R sway bar is not needed, but will make leaving the line more stable. Where in middle Tennesse are you from? Bring it on up to BG some weekend and we'll see.
High Boost!!:biggrin: Going to take more than 20lbs!;) PM me your address I got something to send you!:biggrin:
onalky what does yours run ?
Never had it at the track it made 516whp yesterday at 23.7lbs but then blew up due to a bad crank. Another stock shortblock is going in and it will be 575whp at 27-28psi. Will prob trap 128ish and run anywhere from 10.4-10.7 depending on 60'
