BILL HAINES
R.C ENTOURAGE
- Feb 10, 2007
I'm ready to install the gnx guage assembly. Does anybody know there i can purchase a 30 lb boost guage(stewart warner)????thanks
I purchased the dash assy at paul's world of motorworks. I know that there have been some issues with these assys,mostly no exact directions printed for the install. The guy who did the project(paul) has had some health issues and could not be reached for a period of time,some guys on this board were pssed due to the lack of directions and or procedures of install. Turns out the assembly is the same fit as the actual gnx, but the wiring is much better(john at caspers) john is completing directions on the install,i've kinda been holding off but i want to get started as spring is near in western pa.
82321--should be a 2-30 psi boost gage. You should be able to google sw distributors and find someone with that part. Try summit--try speedway motors--they both handle sw gages. Summit doesn't stock everuthing but when i was battling the install i ordered from summit and they were here in about 7 days. Best of luck. Hopefully paul will get some instructions printed.
did you indeed install this (82321) and does this one have the vac-boost, similar the the one asc used?(but 30 psi boost) reason is that i looked on sw web and they show a 30 psi gage that the part # is 119916... I just want to make sure i get the correct one.... Thanks..
