T Type Rim 86-87 (one in nice shape) ----$50
Steering Wheel (84 GN, very extremely nice) -------------$150
Marker Light (Black, Drivers side) ----$30
NOS defog switch in the box ----------$25
Inspection Cover for torque converter -------$20
Bumper Fillers (OEM, front, in good shape) ------$75 set
Buick V6 longtube headers -----------$50 set
Lakewood Industries Front Drag Shocks, mounted but never run, like new ----$60 set
Wastegate solenoid, used for 2 years, still in box --------$35
Quarter Window (black, drivers side, nice shape) --------$50
Fuel Pressure Regualtors (stock) --------------$5 each
Stock uppipe ---------------$15
Stock Intercooler w/shroud (nice shape) --------$65
Intercooler Bracket (pass side) ----------------$20
Intercooler Bracket (drivers side) ----------------$20
Arm Rest (passenger side grey) ------------$6
Pull Straps (one grey, one sandstone) -----------$15 each
Third Brake Light w/harness and mounting brackets (grey, nice) -----$30
Hot Air Stock chips ---------------$5 each
Fuel Rail 86-87 ---------------$35
Fuel Rail 84-85---------------$15
SFI Body Harness (fuse block to taillight) ------$25
SFI taillight harness (86-87) -------------------$25
84 GN Dash (dark grey, nice shape!) ----------$75
Sill plates (all nice shape) ----------------$20 each
Underhood Light -----------------$5
Tail lights (nice, no bezels) ---------------$50 set
Center Counsol Top, Door w/hinge and shifter applaque ------$50
Stock Airbox mounting bracket ---------$8
Stock Airbox top -----------------------$15
83# INJECTORS w/TT gas chip and TT E85 chip ---------$350
Mirror (Drivers side remote) -------------$20
Ralley Pack Gauge (442 floor shift) ------------$50
Horn Button (84 GN, complete with uncracked ring, NOS new 2 years ago) -----$90
Amber Bumper Lights -----------------------$15
HVAC Complete boxes (one 84-85, one 86-87) ------------$150 each
Brake Pedal w/bracket (powermaster or Hydroboost) ----------$25
Control arms (stock rear lowers) -------------------------------$20 set
Fuel Line Heat sheild (rear) -----------------------------$10
Cam Sensor (complete w/cap) -------------------------$50
Pistons and Rods (Stock) --------------------------$50 set
Shifter (4sp OD) ------------------------------------$25
Seatbelt Actuators ----------------------------------$10 each
Radio Bezel (nice) ---------------------------------$20
Steering Column (floor shift, one grey 86-87, one dark grey 84)-----$100 each
Power Steering Pump ---------------------------------$50
Cruise Control unit (w/wiring) --------------------------$50
Crossmember (200r4) --------------------------------$50
Black Seat Trim (random pieces)----------------------Just ask
Rebuilt Heads (8445, comp 980 springs, valve job, 200 miles on these) ------$150
BQ Trans (core with PTS boost valve and PTS billet servo) ---------$450
109 Block (STD Bore, low mileage block) ----------------------$300
4.1 Block (291 cast, 18K miles, STD bore, could be kept STD probably, very nice!) -----------$400
84-85 Crank Sensors (Used, 2 of them) -----------------$40 each
1984 GM Service manuals (3 of them) ----------------$50 for the set
Black Trim (random pieces) -----------------------------ask
86-87 GN Center Cap -----------------------$20
Complete rebuilt 109 Turbo motor............................Pollished STD/STD crank, Big Stainless valves, mild port heads, Comp 980's, 206/206 cam, double roller timng chain, Earl brown mods to timing cover, .040 Hyper Pistons, Sealed Power Rings, Victor head gaskets, NOS ACDelco lifter set, New Bearings, Baffled oil pan, Stock 86-87 intake and Valve covers, 86-87 turbo flywheel, very nice motor ready to go!!! ------$2000
BQ Grand National Transmission (nice low 42K miles, original and very well maintaned, ready to be installed) --------------------$400
I have a bunch of 84-85 engine parts and brackets, just ask if you need anything. Chances are I probably have them.
