Getting out!, Selling Everything. Lots of Engine parts
For sale:
ARP head studs, Non-Stage block, Used $50
ARP Rod Bolts, Unused, $40
'148 86-87 ECM, No Chip, $40
Kenne Bell Regulator, with Fuel Rail $60
MSD 50lb injectors, and Joe Lebrant Chip for 93 Octane $175
Stock 86/87 Upper and Lower intake, bead blasted, unported $150
Stock 86/87 Turbo, Some shaft play, no bent fins, complete minus inlet bell, $75
New TRW Single Roller timing chain for use without tensioner $25
Pass side 86/87 Header, Jet Hot coated, great shape $100
8445 Heads, back from the machine shop, 3 angle valve job, new seals and Comp 980 springs. Unported. $150
84/85 Turbo Block, Stock bore, honed, back from the machine shop, new freeze plugs and cam bearings. $150
Stock turbo crankshaft, STD/STD, journals are in great shape, SOLD
Stock 2 dot rods, with stock pistons, great shape, $50
20 bolt timing cover, bought from intercooled88ss, $30
Turbo Riv Wiring harness, could use some repair, $30
Regal 3.8l frame pads, $15
Erson 214/214 flat tappet cam, with lifters, packaged individually so they can get put back in the exact same spot. $50
Buick Engine to Chevy Transmission adapter, Brand new. $40
I can get pics of everything. Prices are plus shipping. PM me, or call me 405-532-9470
Is that an aftermarket or does it have a GM part number on it. Price shipped to 78023. Thanks.
I'll take the ECM please.
Is the Chevy trans to Buick eng adaptor just a plate with a bunch of holes in it or is there something that takes up space in the converter and crank flange area? If you have all the stuff the manufacturer supplies with it I'm interested in that too.
ECM and Trans adapter Sold!.
I also have a walbro 340 High Pressure inline fuel pump, -8 Aeroquip lines, fittings, -10 inline fuel filter, came off of a Turbo mustang LS1, worked fine. Also for sale $100
