S SPOOLN Member Joined May 25, 2001 Aug 7, 2008 #1 Who sells 3.23 gears that are as quiet as the stock 3.42s . I know Richmond sells the 3.23s but i heard that the Richmond gears are loader then other brands. Is Motive gears the supplier for GM cars? thanks
hflwyo Active Member Joined Jun 5, 2007 Aug 7, 2008 #2 I have had good luck with Yukon gear but I think Motive is also good too.
M mygn276 Member Joined Feb 4, 2006 Aug 7, 2008 #3 I have the richmond 3.23 in mine. It is not noisey at all and i like it.
M mikestertwo Well-Known Member Joined Sep 13, 2006 Aug 7, 2008 #4 I'm also running Richmond 3.23's nice and quiet. If they are noisey, they are not set up correctly.
S SPOOLN Member Joined May 25, 2001 Aug 7, 2008 #5 Thank you for the feedback on the gears. How much difference in performance did you notice when going from the 3.42s to 3.23s.
petty New Member Joined Aug 8, 2008 Aug 8, 2008 #6 Got heard that replacing a gear would be expensive for about L3,573.49. I might just get a second box fitted then I'll might be trading my car. ____________________ Autopartswarehouse Auto Mods.
