Only one side of the fuse will have power. If you pull the fuse and check the box with a test light one side will have power and the other will not. the fuse that says cig clk should be a 20 amp fuse its right above an orange wire that comes out of a connector. almost center bottom. If you have power on both sides of fuse you have other problems. If there isnt power at fuse block then you may have a bad link at starter. I would pull that fuse and replace it. good luck
