Fuel pump hotwire kit
Braxton Jordt
I installed a fuel pump hotwire kit and now when I turn the key to on, the fuel pump won't stop after it's done priming. I put a new acufab regulator on thinking my old school adjustable one was bad but same problem. Any ideas?
Make sure the return line that comes off of the paasenger side fuel rail is flowing, could be pinched or stopped up forcing the diaphram to stay open in the regulator! Just a thought
These are the wires right above the oil filter and behind the rad hose. These the right ones?
Them are It. An having the ends exposed might be the problem. Also check grounds
86 Regal W-11/CC-1T Type
