i was having problems with fuel pressure so i removed the fuel pump from my car. i feel pretty dumb because the tank was practically empty, problem solved. it turned out to be a blessing in disguise because i noticed the hose attaching the actual pump to the fuel line (inside the tank) was very scammer and it fell apart easily when i took it off. is there a certain kind of rubber hose i should be using?
