Hatdragracer
- Jul 2, 2012
Orange data is Fuel Pressure, Green data is Boost
At the peak of the boost is 21.1 lbs
Fuel pressure dropped to 43.6 lbs
TPS was at 59%
Injector duty cycle was 96% (yikes)
AF Ratio was 11.6
Alky was on
No ESC Retard
Stock Fuel Rails and fuel lines
I have a Walbro 340 pump with a hotwire kit so I never thought I would have to worry about fuel supply with mild setup.
I will start with a new fuel filter to see if that is the issue, I also have an Accufab regulator that I have not installed yet....I dont think it is a regulator problem as the FP follows boost well until higher boost levels. On this run the FP followed the boost 1:1 until about 12 psi of boost then trailed off, the FP caught back up when I let off the throttle.
Do the Accufab regualtors have lower resctriction than a conventional Adj. FP Regulator?
TPS was at 59%
AF Ratio was 11.6
Alky was on
No ESC Retard
