So when I was replacing my cam and crank sensor I took the intercooler out for clearance and to clean it all up. When putting it back together one of the fuel lines is rubbing against the intercooler bracket, and is about an inch away from the other fuel line. I obviously don't want it rubbing, I'm thinking of relieving the fuel pressure, loosening the fittings on both sides, and seeing if I can get it to sit closer to the other fuel line.
Is there some kind of trick to this? I didn't see the line rubbing before, but it is definitely rubbing now.
