F flattype New Member Joined May 11, 2006 Apr 27, 2007 #1 My fuel gauge jumps around intermitantly. Some times it will sweep all the way past full then drop back to the correct point. Any ideas? I replaced the fuel pump about 3 weeks ago hope I didnt mess up the sender.
M mikestertwo Well-Known Member Joined Sep 13, 2006 Apr 27, 2007 #2 Sounds like you have an intermittent open wire going to your sending unit. Could be the sending unit itself.
I IL KIM New Member Joined Nov 7, 2006 Apr 28, 2007 #3 I had the same issue and fixed it. Courtesty of gntype.org Blank
