I just finished installing a dual fan, scan master, fuel pressure regulator, maf pipe w/kn filter and I believe its called a "Patriot" chip. After installing I set the fuel pressure regulator at 45 with the vaccum line off. I then took it to work the following day with a full tank of gas and barely made it to work. Needless to say I wasted $40.00 dollars roundtrip and work is only 35 miles from my house. My gn is currently all stock except for the above mentioned stuff and a walboro 340 hot wired. Any help is always greatly appreciated.
